Well the install went smoothly, fluid looks good, no material in pan, trans shifts nicely, hasnt set 1811, or requested full line pressure. I have a trans cooler to install, its a 25,000 GVW. Thats next.:th_thumbsup-wink:
Just to clarify for future readers.....I still wonder how many folks have spend hundreds and even thousands on these transmissions for this issue when the fix is relatively inexpensive and easy. Good luck!
The shift kit is not a fix, it is a band-aid/temporary solution. Until the problem (typically PCS) is replaced, you have not "fixed" the problem.
But you still have a broken part(s) in the vehicle. Until it is replaced, you have a band-aid. Possibly a really good band-aid, but a band-aid none the less.This statement is incorrect!
The 1811 code (PCS) first showed up in my GP at 90,000 miles and after installing the Transgo shift kit and the tranny coolers with the cooling outside of the factory radiator cooling, the trans now has 160,000 miles on it. The hard shift issue has NOT occurred once in 70,000 miles of all types of driving-so much for a temporary fix-that was 5 years ago. The issue has been fixed on my car.
Correct, thus why I said "typically".I have to agree more with jbamonte. The PCS is NOT necessarily the cause of the P1811.
the PCS electrically controls the pump line pressure in conjunction with the mechanical control from the springs/shims in the accumulator. The Transgo shift kit replaces the shims/springs in the accumulator and effectively transfers the line pressure control previously performed by the accumulator AND the PCS solenoid to having all control of the shift/line pressure to the accumulator ONLY, since the PCS is no longer working correctly which is the E in the 4T65E trans name. This control is basically the same control found in the 4T60 previous version of the transmission, and the mechanical control used in transmissions forever prior to the electronic versions. An inoperable PCS corrected with a shift kit will operate correctly forever if that is the only issue and has zero effective on the operation of the transmission and mileage. It is a permanent fix for a hard shift condition caused by the PCS-replaces one type of control with another.
Essentially what is happening with a hard shift condition is that the as the springs/shims in the accumulator get mileage on them, the springs lose tension (become softer) which extends the time between shifts. When the computer detects longer shift times either from the accumulator springs losing tension or other issues in the transmission that occur with age/mileage, the computer tells the PCS to up the line pressure which is trying to reduce the shift times between shifts with higher line pressure-Thus the trans begins to shift harsher. The trans fluid temperature component of this issue is that very high trans fluid temperature will make the accumulator springs even softer which is why high trans fluid temperature often triggers the hard shift condition-thus where the trans cooler come in.
The following quotes are directly from the Transgo shift kit instructions:
" With 70,000 miles or miles on the 4T65E transmissions, they often need some hard parts"-mine had 88,000 miles when the first hard shift condition existed.
"Long Shifts make a 1811 code with default to hard or missing shifts. A scan tool will show long shift adapt time. This kit will shorten the shifts without making them rough" This is true!
"EPC (PCS) solenoid-This solenoid fails with no metal contamination even on a perfectly clean low mileage transmission" Thus my comments and my personal experience that changing the fluid/filter often will not prevent this failure.
"EPC (Pressure Control Solenoid)-P1811 or PO741 and other codes and failures are most often caused by a sticking armature in the EPC solenoid" This is an electronic issues and has nothing to do with the fluid.
Hope that this helps and addressed the naysayers.
Assuming you mean this as a preventative measure?Religious filter and fluid changes probably do more good than the shift kit.
I agree you are not a transmission expert, therefore you should not be putting people down that have far more experience and understanding about the situation. Not a kick in the balls, it shows in your below quote that you don't fully understand the issues behind a long shift time and the pcm commanding max line pressure.
P1811 is the code letting you know that the pressure has been commanded to maximium by the pcm for a shift. It is not a long shift code, it is not a weak spring in the accumulator code. Many builders have found that even after putting in a new EPC and a full shift kit in the accumulator that they can still end up with a P1811 from long shift times. There are many factors that cause a long shift time. EPC not keeping up is the most common one, play in clutch pack tolerances is another. Your direct quote about the EPC having a sticking armature (mechanical, not electronic BTW) is explaining the true problem is the EPC.
The accumulator is named well. It accumulates fluid and when the springs overcome the fluid coming in, fluid will then flow behind the clutch piston faster and engage it. The amount of fluid needed (worn clutches or slop in clutch pack tolerances) can have a large impact as well. The more fluid needed overall makes the shift time longer. By shimming the accumulator, you limit it's movement and force fluid to the piston faster. This causes the shift to happen sooner, keeping the pcm from seeing a long shift time and commanding maximum pressure shifts.
By limiting the accumulator movement, you are bandaiding other issues that exist in the transmission. As well, you aren't installing the full shift kit by only dropping the pan and putting most of the kit in the accumulator. There are other parts in your transgo shift kit that require you to take the side cover off and go into the transmisson much further for a proper install.
I'll stand by a shift kit as being a fantastic bandaid for a problem that requires a good amount of labor to fix the actual issues.
That's what I figured you meant. :th_thumbsup-wink:I was only trying to make the shift kit sound like less of a magic cure. Just installing accumulator springs and spacers is only masking the issue not fixing it. I am positive it will shorten shift times just not fixing what is broke. If you do have a trans problem new fluid rarely does any good. Religious fluid changes are always good for your transmission though, its just once a problem has occurred its too late.
I love all of the transmission "experts" who spout off about "the underlying problem" and band aids in that high and mighty "what a bunch of dumb amateurs" tone. I brought my 4T65E to several "experts." Each was more than happy to charge me for a full diagnostic. Not a single one was able to tell me what was wrong. Every single one told me that that I needed a rebuilt transmission installed, but not a single one could tell me why. Not a single one rebuilds these transmissions anymore because they are basically grenades and apparently none of them could tell what made the pin stay in or fall out (metaphorically speaking, of course). I am not kidding. They all order rebuilds with warranties because it's apparently the only way not to lose money on these dumb things. When they grenade again someone else is on the hook.
GM put out an early TSB on the P1811 and EPCS and later withdrew it. There is nothing in its place now because apparently even GM can't tell you all of the different kinds of things and interacting things that go wrong with these transmissions and/or with their control systems - because the problems with electronically controlled transmissions, as we know, is not always IN the transmission (or the converter).
And the P1811 is a long shift code. Max line pressure is the fail-safe put in place when the long shifts are detected so that the long shifts don't continue to burn up the clutches. What causes the extended shift times? Apparently any number of things that no one is ever able to figure out. What "cures" it? Well let's see...the $100 "band-aid" fix or the $4,000 "band-aid" temporary rebuild non-fix from the "experts." I think anyone doing battle with one of these disastrous transmissions is capable of doing the math and then making that decision themselves. There is no need to hang around talking the "right" way. The "right" way is the one that works, and I have yet to find any transmission "expert" who knows what that is on the 4T65E.
