GOTIT4CHEAP16
so running the car without the supercharger belt makes it an N/A? Didnt know that. That could probably save someone gas
also i was told as a rough estimate basically 4 cylinders you use 87, v6 use 89, and v8 use 93 is that true?
your saying you cant afford gas thats 4.00 per gallon. ... 87 is 15 cents or so less per gallon .....
I also run my 00 Grand Prix GT and 95 Bonneville SE on 87 and they seem to do just fine. Haven't lunched a motor yet due to knock. Stop listening to people that may give bad info, read the owners manual for EACH car you own and follow their recommendations for octane levels and you should be fine.
Your NA GT/SE can get by with 87 with no problems, top swap and run 87 and tell us how far you get. :th_jester:
If you are using 91 or higher octane unleaded
gasoline and you hear heavy knocking, your engine
needs service."
