    TIPS:
Sale 3800 Performance PCM
thatgtpguy
I have a 3800 Performance PCM for sale. I installed in my car wasn't to my liking. Im going to go the custom tune route. Ill sell for $75 OBO or will possibly do some trading. PCM was installed in a 02 GTP
[SIZE=-1]FEATURES:
- Speed limiter removed
- 3-1 and 4-2 skip shifts (Active in performance shift mode only*)
- Transmission line pressure increased (Active in performance shift mode only*)
- Shift points moved (5800-6000rpms) (Active in performance shift mode only*)
- Fan turn on points altered:
- Torque abuse modes are modified to eliminate bog at launch
- Part throttle KR issue fixed
- Removes lag by changing downshift tables
- 185 degree turn on
- 2 minute fan on at key-off (this feature activates when engine coolant is 180 degrees or greater)
- MAF calibration adjusted for proper operation and year
- En-richens fuel delivery for critical problem areas
- Provides a consistent power gain across the entire power band
- Reduces spark retard (knock retard)
- Removes “40MPH WOT lag”
[/SIZE]
