So I've had the timing cover on my 3.8 Camaro (not a W-body, but same engine) leak coolant around the water pump, and I now plan to replace the gasket as it is leaking more and more. I've tried to replace the timing cover gasket before in the past, but I am still uncertain if I had done something wrong or the engine had already been fried out (The engine had rod knock when I tried to replace the timing cover). In the past after the replacement I've had coolant appear in the oil after redoing the timing cover twice, so I just wanted to ask what the proper way to replace this gasket is.
Just a few questions,
-Black RTV on all bolts?
-Should the gasket itself be covered in any sealant, or just dry gasket?
-I've been looking for the harmonic balancer bolt and couldn't find it anywhere, I know it is said to be torque-to-spec, so if I reuse the old one, what could happen?
-Any other pointers?
