OH4CompG
All items located in Salem Oregon
Pulley boys/smoothflow 3.2 mps pulley (black) and 660 belt to run it - $40 shipped
I'll add more as I think of it
My days off from work are usually Mondays and Tuesdays. I will get these items pulled ASAP once I have commitment or paypal but might not happen until Monday/Tuesday and will ship same day as pulled. Best to reach via PM but I will check this thread periodically.
SOLD ITEMS
Dynotech 300m input shaft new never been used - SOLD
AEM Oil pressure gauge with sensor and wiring with the needed adapter for tapping the oil pressure port by the filter - SOLD
Alternator spacers for install of FSIC with a Gen V - SOLD
Blue front license plate filler off of my parts car. Good shape. Will polish up nice - SOLD
Aeroforce Interceptor Scan Gauge in red with black face - SOLD
MSD Coil packs - SOLD
Gen V throttle body turndown (necessary for FSIC installs with an 04+ car) - SOLD
ZZP Modded stock fuel rails for intercooler for 97-03 L67's - SOLD
ZZP Upper poly square mounts in clamshells - Sold hester21289
ZZP Poly lower engine mount - Sold
ZZP Poly trans mount - Sold
SSIC intercooler core for a Gen V - Sold
ZZP 3.0 pulley black - Sold to Angelo00GTP
Custom 2" core FSIC with pcv function for gen v - Sold to GMR Badass
04+ Gen 1 ZZP triple pillar pod with small crack towards the top (unnoticeable when installed) - Sold to Ginseng
ZZP MPS hub - Sold to Bluemagic
AEM Wideband O2 with sensor. Approximately 1000 miles on it - Sold to Ginseng
Quaife ATB Differential with the bi-metal washer update for the planetary gears. When installed it had chatter at low speeds with wheels turned. Otherwise performed as it should. If you buy this, expect it to need some work - Sold to GMR Badass
SOLD ITEMS
