3.0 Pulley????
Uno99
Donating Users
Who is running one, and with what supporting mods? Anyone think I can get away with a 3.0 pulley with my mods? Also how much boost are you getting with your 3.0 pulley?
3" DP with high flow cat
3" Exhaust wtih FloPro mufflers
Intense S1X Cam
Roll Master Single Roller Timing Chain
Balanced shaft disabled
CompCam 105lbs. Valve Springs
CompCam Titanium Retainers
Intense MPS with 3.2" Pulley
Ported Exhaust Manifold
Updated ZZP 1.0 PCM tune
K&N open element filter (PFYC)
YES get injectors...probably 42.5# ones...and a REALLY good investment at this point would be headers, and a ported (or LS1/N*) TB and blower would be great addiction to get rid of the knock retard you are prolly gonna gret with the 3.0"
I had a bead on a brand new set of pacesetters from a local guy but snoozed to long and he sold them. He wanted $350 for them. I really need a local tuner too. I hate having to send it out.
how much timing are you running with that 3.2? you may be better off sticking with that and more timing.
A scanner would be a very smart investment at your mod level. If we had a scan we could probably tell if you would be able to drop pulley sizes or not.
^^Likewise. I wouldn't drop a pulley until you get a scanner. I still say get the headers before anything. You'll be glad in the end IMO
Probably just about any used scanner you find in the classifieds. I'm partial to the GM enhanced Autotap scanner, it was probably the best scanner I've used yet.
i second the auto tap. make sure it has "gm advanced parameters". used ones are usually priced $125-175 but most often right at $150.
