2013 Fiesta Rally All teh Things 8=============D (|) (_*_|_*_) i can haz mud flappers
Re: G8X 11/14/11 Headers / Bunch-o-mods
^^^ yupp same one before parts were shaved
Re: NYX GTP 12/06/11 Personalized Plate
it might be the pictures, but that black does NOT look good.
^^^ it def isn't
seeing as how it's 8 diff shades of black and 3 diff finishes
so i talked w/ my buddy and he's gonna help me shave the holes from the door ding guards , help me pull the dents and remove the finger hole for the gas door, ( that one if i can find some good sheetmetal) so should i rob a gp of a door or trunk lid. something like that.
i'll ask him about the trunk key hole too
long update
here is the push button start
got tired of the gtp sitting on my desk
getting some grand am badges to throw on the car
the ****ty hid's i have
a rare sight in florida
i removed the check engine light and abs light since i check the codes once a week anyways
bottomed out one too many times and had it welded together
had all the other band clamps tacked on so the wouldn't come off
the one that was 6" away broke off when i hit the deer, welded it at home, then my first wot since then the other one went just now. and that is the last band clamps except on the mufflers
random
deer: theses are in chrono order from when it happened
so getting tinted heads in, tinted tails, flip has my tinted fogs but they are too big to fit the bumper on the car. getting in some decals and some grand am badges
Were you really that guy who enters his POS in a car show in the first picture?
I was but it wasn't judged. Parking ass limited and expensive for.the event so it was cheaper to just pay 20 andgetin show parking and a goodiebag for 2 days. The 2nd day I left early and mhnamewas called for an audio drawing
Kindle Fire: 58 pixels were harmed or maimed in the making of this post. Congratulations on becoming an accessory.
Re: Super Chode (Because ROOF RAILS = Bigger Penis)
**** to buy / plans
"stage 1" (back to stock + ****)
zzp stage 1 axles 174.99
zzp supercharger couple + gm oil 44.98
zzp poly engine mount 59.99
zzp poly tranny mount 89.99
zzp poly dogbone 29.99
zzp wheel bearings front 159.98
zzp wheel bearings rear 169.99
DRCustom Parts STB Brackets 90.00
zzp valve cover gaskets 19.99
GM door handle repair 85.90 (65.20)​
zzp injector o rings 9.98
zzp fuel line tool 6.99
zzp alt volt booster 19.99
me alt rewire
me big 3
me battery in trunk
eaton snout fill plug 4.99
water pump / gaskets
LIM gaskets
s/c gaskets
oil pan gaskets
cradle bushings
tie rods
ball joints
springs
struts
coolant elbows
strut top plates
sway bar bushings
tie rod bushings
phoenix tune
fuel filter
pvc valve
door weather strippings
cabin air filter
rear window seal
trunk weather seals
"Stage 2" (some ****)
zzp catback
sd headers​
electric water pump
mps hub
3.5 pulley
f/s innercooler
Guy, think smarter not harder.
Dont be a ZZP nut swinger.
You dont need ZZP stage 1 axles, napa axles with lifetime warranty work just the same.
or any of these things:
front and rear wheelbearings, buy TIMKIN and dont waste your money.
ZZP coupler + oil, ebay is way cheaper for the same thing.
Electric water pump
zzp catback
I just saved you a **** ton of money.
