2008 GXP engine missing
mytsharpgn
Hello all.
Just joined this forum at the recommendation of a friend of mine. Lots of great information on here but as a newbie I'm having trouble locating some troubleshooting information.
I've owned my 08 GXP for about 2 months. Bought it with 53k miles and it has 55k on it now. Yesterday while sitting at a stoplight, the engine felt like it started to miss. It was hardly noticeable, every 3-4 seconds, but enough to kick on the CE light. After moderate acceleration away from the intersection, the car was running normal, but after reaching the highway speeds, I noticed the TCC solenoid was not locking up. RPMs at 60mph are about 2100 (higher than normal). Instant mileage on the DIC was 17-ish, much lower than what I am used to seeing, which seems to indicate I was still running on 8 cylinders instead of four (a result of the TCC, I would assume).
Driving it today it was acting the same as yesterday. Minor missing while stopped and in gear, no miss while driving.
When I got home tonight I plugged in my OBD II scanner to find out what code was set, and it failed to read. So I unplugged it, took it to my wife's 07 Trailblazer, plugged it in and it instantly hooked up and read diagnostics. So I took it back to the GXP, plugged it in, and it failed to read any codes.
So I'm looking for some insight. First I'm at a loss as to why my scanner is not working. Second, since I can't get any codes, is there something I should be looking for? My first thought is replacing the PCV valve, but I doubt my luck will be that good. Are there any things known to go bad on these cars?
Thanks.
Kirk.
on the gxp the notorious thing is the trans. ive never heard of this. i looked through all the stuff on gmls4.com and found nothing there either. wish i knew. maybe try going to autozone and seeing if their scanner works on your car.
friend has an 05 gxp ran like **** for a wile, then he found it had a cracked spark plug
