2008 Grand Prix seat
Abbby
My drivers side tan leather seat has a large tear in it. I am trying to figure out best option to swap it out. Anyone have any advice here? If I find a complete heated power seat I could just swap out. Could be hard to find and pricey. Seems another option might be is to find a passenger base and just swap out the bottom cushion portion only. Much easier to find a passenger one in good shape. Looked underneath and it looks like there are 4 bolts holding the cushion in. May still have to take complete seat out to do this.
[FONT=&quot]GM Service Information [/FONT]
[FONT=&quot]2008 Pontiac Grand Prix | Grand Prix (VIN W) Service Manual | Seats | Seat Hardware, Trim, and Upholstery | Repair Instructions | Document ID: 1715831 [/FONT]
[FONT=&quot]--------------------------------------------------------------------------------[/FONT]
[FONT=&quot]Front Seat Replacement - Bucket [/FONT]
[FONT=&quot]Removal Procedure[/FONT]
[FONT=&quot]Caution: Refer to SIR Caution in the Preface section.[/FONT]
[FONT=&quot]Important: The front seat is equipped with a seat belt pretensioner. Disable the pretensioner before you perform any work on the seat. [/FONT]
[FONT=&quot]Disable the SIR system. Refer to SIR Disabling and Enabling . [/FONT]
[FONT=&quot]Remove the front seat head restraint. Refer to Front Seat Head Restraint Replacement . [/FONT]
[FONT=&quot]Position the front seat to the full forward and the full-up position. [/FONT]
[FONT=&quot]Remove the bolts from the rear of the seat adjuster. [/FONT]
[FONT=&quot]Remove the nut from the front seat belt bracket, on the door side of the seat. [/FONT]
[FONT=&quot]Tip the seat forward, remove the position assurance pin (2), and disconnect the pretensioner electric connector (1). [/FONT]
[FONT=&quot]Disconnect the electrical body harness from the seat. [/FONT]
[FONT=&quot]Tilt the seat forward and slide the seat back to disengage the adjuster hooks holding the seat to the floor pan. [/FONT]
[FONT=&quot]Remove the front seat from the vehicle. [/FONT]
[FONT=&quot]Installation Procedure[/FONT]
[FONT=&quot]Install the front seat into the vehicle. [/FONT]
[FONT=&quot]Engage the front seat hook attachments. [/FONT]
[FONT=&quot]Tip the seat forward, connect the pretensioner electric connector (1) and insert the position assurance pin (2). [/FONT]
[FONT=&quot]Connect the electrical body harness to the seat. [/FONT]
[FONT=&quot]Notice: Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems. [/FONT]
[FONT=&quot]Install the adjuster to floorpan bolts. [/FONT]
[FONT=&quot]Tighten [/FONT]
[FONT=&quot]Tighten the bolts to 42 N·m (31 lb ft).[/FONT]
[FONT=&quot]Install the seat belt and nut. [/FONT]
[FONT=&quot]Tighten the nut to 42 N·m (31 lb ft).[/FONT]
[FONT=&quot]Install the front seat head restraint. Refer to Front Seat Head Restraint Replacement . [/FONT]
[FONT=&quot]Inspect the front seat for proper operation. [/FONT]
[FONT=&quot]Enable the SIR system. Refer to SIR Disabling and Enabling . [/FONT]
Here you go. This is tan leather and heated (you can tell by the pictures).
https://rover.ebay.com/rover/1/711-...ash=item51ee4eabc9:g:J0YAAOSwQjNW8ttg&vxp=mtr
I also use this stuff on my leather seats, cleans them up great and protects them.
https://rover.ebay.com/rover/1/711-...172162&hash=item25d2d063cd:g:nUgAAOSwuxFY3W-5
If you have a pic and pull or a pull and save or equivalent look there. I have a 00 and got front seats from a 06 for $27. Mounted right in no modifications needed.
