2007 Grand Prix GXP
The compressor tool that I need if I replace the mount, is that a tool I can rent from Autozone that you know of?
Sent from my 2PQ93 using Tapatalk
I m sure they have them. Yeah there is 2 in a set.
That 22mm offset box wrench comes in mighty handy ya know....amazon has a good selection
7/8 works but is kind of sloppy
The Autozone I went to only had up to 19mm box wrenches, so I'll order a better set online sometime
I found just the 22/18 offset for like 9 bucks on Amazon.
You really could use some different washers on top to. Those stock ones are ok in the back but not the front.
By the way dont even bother trying to tighten those(the right amount of thread showing) They are tight, it's the mount that fell apart
Dang =/ well I will probably order the mounts then. And I'll get the wrench and everything. Do the washers need to be ordered separate?
