If anyone out there can help me, I'd sure appreciate it. I have multiple symptoms, but can't tie them together (if they need to be).
Low Cabin Heat
Outside Air Temp. = 51°F
Discharge Air Temp. = 102°F
Coil Inlet Hose = 160°F
Coil Outlet Hose = 135°F
Coil backflushed with no improvement
Coolant
Coolant just flushed but looked and smelled bad prior to flush
Contaminants (oil?) still present in new fluid (darker but not as bad as before flush)
System vented of air
Oil
Oil clean but just changed less than a week ago
Car has used oil for over two years not, but no external leaks nor smoking
Periodically Overheats
Thermostat replaced 6 weeks ago
Other
Transmission Fluid clean
Power Steering Fluid clean
No external leaks
No smoke at all
No loss of power
Car runs smoothly
Low Cabin Heat
Coolant
Oil
Other
No external leaks
No smoke at all
No loss of power
Car runs smoothly
