Also while you're in there if you want to convert your fuel module to AN lines I got some pics of how I did mine
Thanks for the help and pointers. I am not sure what I am doing with the fuel system yet. no matter what it will be dynamic, but I might just fabricate a cell in the stock location with an Aeromotive Eliminator pump, or maybe a Holley Dominator.
A lot of good things happening in the wbody world right now! Maybe the platform isn't dead!
Not even close!
We are working on a few other tid-bits as well.
sure as **** makes you wonder why GM didnt do it....
when i measured a charred to hell ls4 the distance from the crank centerline to the skirt looked like the engine and trans would both be fighting over the same .5 inches of real estate and it looked like it was right at the thin part of the block skirt, not a meatier area like the main web...
is there room on the blocks bellhousing face to drill and tap the block for the new "***** bolt" location?
As far as modification to fit the motor, the crap bolt on the block needs to be removed. There is no room to drill/ tap to add the bolt hole back. If you loook at this picture of the motor on the stand, you can see the recessed area around that bolt location. I literally used that as a cutting guide to remove the material and it fit like a glove. It's like GM included a dotted line LOL.
The other area that needed modification was where the differential/ output shaft cover bolts to the transmission. Right at that spot I removed roughly an 1/8" of material from about a 3/4" long area of the oil pan rail and one little stub on the block.
The finished product obviously looks a little nicer.
Next on the list is to make a template for the starter pad so I can cut the bellhousing, index the pad and weld it on.
Either way, at this point it is a very promising conversion.
This makes me want a 4t80e. I'll be watching this thread for sure. Awesome work!
Thanks!
______________________________________________________________________________________________________
Set the driveline square last night and started building the mounts. Pretty busy at the shop, most likely won't be back on the project until Sunday unless I get one good solid late night during the week. Time will tell.
