SyntheticShield
Okay so basically we are back on track then. The P0116 would point to the coolant temperature sensor.
hello
i'm new to this forum. I've been searching the net for problems like this and may have an answer to your problem.
I own a 2007 grand prix and live in winterpeg. I have had the same problem 2x now. If you plugged the block heater in and the temperature was warmer than -20 deg c when you started the car, a code has been set in your computer. This code disables your temp gauge and runs your fans all the time. It also runs the engine rich thinking the engine is cold. When you try to restart after the engine is warm it floods itself.
When the code is reset the engine and guage return to normal.
The problem is not just with the grand prix but includes other gm cars and trucks.
Today i was about the 12th person to have this fixed at my dealership.
My car is under warranty so the fix is free. This problem is known to gm and requires a fix(hopefully soon)
a dealer should be able to clear your code in a few minutes while you wait.
If you replaced the plug end you may have cut off the thermistor.(A round bump in the cord near the male 120V plug) There is very little cable from the plug to the thermistor. If the thermistor is missing you will require a new cable.$$$
