just get a full l32 top lim heads s/c map rail and injectors harmonic balancer and ideler pully reason i say l32 s/c is because it is more efficient and easier to put ur tb on to
boost bypass valve....
I know it is more efficient, but I am not really going to be pushing the blower to it limits by any means. I have no interest in that. Also just because it is easier to put my TB on is no reason to go withe the Gen V blower. If I can't do this for >$500 I'm not doing it. But I can get the L67 heads, valve covers, all the pullies, belt tensioner, harmonic balancer, LIM, Gen III blower, and all the sensors I want off a running 98 Grand prix gtp for $250... That REALLY helps me reach my goal of less than $500 for a top swap. I still have a couple things to figure out like which company can actually tune for me and if they are going to give me a GTP PCM or just tune my PCM. This really isn't that hard or expensive though, and I'm here to prove it. I will have a 100% DETAILED walk through of a Gen III (L67) top swap on a 2004+ Grand Prix when I am done.
barometer measures pressure, thats what the MAP sensor does. MAP means Manifold Absolute Pressure.
You dont need to hook up the BBV (Blow by valve) solenoid as long as you turn traction control off every single time you turn the car off. If you do not wish to disable traction control all the time, then you need to hook up the BBV solenoid.
I'd wire in the BBV. That's just me though. The car should run okay, but I don't know that it'll unload ergo possibly killing gas mileage. But I'm not 100% on that.
What do you mean it won't unload ergo? ERGO?
What is the purpose of the BBV, obviously is bypasses boost, but why?
Ergo... I mean 'therefore'.
You don't always want it to be pushing boost. Like when you are cruising down the highway at 70, you don't need boost. BBV to the rescue.
it opens and closes based on vacuum 95% of the time, but the computer can command it to open to dump boost under conditions like traction control.
YES, you need the MAP sensor.
1. Do I NEED the baro sensor? (same as map sensor)
-If so does it have to be from a 04+ GTP or does it have to be from an L67 engine? Since I am doing a L67 top swap I am assuming I need to get the L67 MAP sensor, could be wrong.
I've said before I don't work on 04+ much, so take this for what it's worth; the computer uses baro readings for various calculations, so yes, you need the baro sensor as well as the standard MAP sensor in an 04+ L32 tune. The sensors are different on the L67 vs L32, but I'm not sure why. Just get the L32 sensors and be done with it. Wiring is going to be another issue, though.
Well this is going to be fun. I dont think anyone has done a L67 swap on a L26.
