2004 and up reverse light assembly
Rnungaray08
I have a 2006 GXP and my reverse light assembly is really opaque. Is there any way of cleaning it or not? Would a headlight restorer kit also clean it up a bit or it has no chance?
Bro I'm just gonne polish mine up real good and have the shop put some tent on it. Not dark but enough to go with car color better
If you tint the reverse bar, leave the reverse light squares clear or you'll need some damn bright reverse lights.
I used one coat for my reverse bar still stock lights and can see fine if you just want to get the oxidation I recommend wet sanding with 1000grit and then 2000 then clear coat
I actually ended cleaning it up really well. I had one of those kits for headlight restoration that came with a piece for the drill. I used that on some meguiars compound, and it looks new. I topped it off with some speed wax and it was good to go.
