Don't know if this is the right spot but oh well. Anyways my rear view mirror fell off, anyone know what the sticky stuff is that holds the mirror in place?
if you are talking about your rear view mirror in your car, you can get a do it yourself kit at any auto store or even walmart for around 3-5 dollars. Its called rear view adhesive. Just mark the old mounting place on the outside of your windshield by tracing around it(old mounting area) with a crayon or window chalk. Then go back inside your car and clean the area where the old glue is thoroughly with some rubbing alcohol or the wipe that is included in the rear view mirror kit. Make sure you separate the mounting bracket from the mirror. Then take a small amount of adhesive and apply it to the mounting bracket(make sure its on the side that mounts to the windshield) Take your bracket and apply it inside the area where you previously traced it and apply a firm pressure for a few seconds. Let that adhesive set up for a while before reattaching the mirror otherwise it will fall right off again. Hope this helps.
