Aaaaannndddd bam! My first thread picture
congrats on your new car btw! My first GP was my mothers too.
if it didn't just snow were i live i would take my dash off. Well first you are going to need aftermarket radio harness 20$ and an GM antenna adaptor 20$. Also to make this look good you might consider a sheet of plastic to cut and fill in gaps around the radio or any other way you want, and paint? Cool now take off the dash. The plastic is brittle on our old cars so take it easy, your going to need those clips too. Unplug everything and remove the radio. Unbox the new radio and see how it sits. Now obviously you can see that the heater controls are in the way, its easy to unscrew grind off the plastic pins, drill new holes and install the new screws in a lower spot on the plastic it originally screwed into. Be careful here because it can be to low and the knobs will hit the dash cover (measure twice drill once) you want it as close as you can get so the knobs wont hit.
