2000 Regal
BillBoost37
I've talked a bit about how the car looked when I got it. A recent thread made me think..I'll show how bad things were when I bought it.
I was looking for a 2000+ Regal, criteria, L36, not black or white, has sunroof and folding rear seat. Max contacted me about a white, l67. Well the body was right. I hopped on it. It was filthy, needed suspension and brakes, had 160K on everything.
Had a few lights on
Avg mpg of 16...lol
Like the cupholder? (note no seat heaters)
Hvac dim
Water stains on both sides of the headliner
Passenger seat had newspaper print on it
Glove box wasn't connected properly
Drivers mirror was bad
Most of the stock chromies leaked
Enough of the bad
Out came the pressure washer
The interior got stripped. Trunk and all were matted with stuff from second skin audio. Inside the doors and trunk lid were sludged.
Pulled out the stock monsoon audio system, amp, wiring, headunit. In went a Pioneer HU, all new wiring, Boston Acoustic 5 channel amp and Boston speakers all the way around including a sub. Backup camera and all goodies.
Amp wire run through the boot and to the battery
Added turn signal mirrors and puddle lights
Power washed carpet, cleaned the seats, added heaters to them with stock switches, good cupholder, HUD, extra power outlets.
Changed the mirror to a Nissan/Maxima one with Homelink
Suspension:
All the rear stuff was swapped out. Toe, lateral and drag links. Upgraded calipers to the 08 ones with ebrake on caliper, GMPP sway with ES urethane bushings, Moog endlinks
More to come
SS brake lines all the way around, vogtland springs
Pulled the front subframe, mount, oil pan and replaced with aluminum pan, it's mount, aluminum subframe, new controls arms, GMPP sway, ES Urethane links and bushings, f body brakes with R1 Concepts rotors and pads
It was time
Going back together and coming along well
Poly mounts all the way around
Backup cam
Sequential tail lights
Lucerne 18" rims
Goodrich RE AS960PP tires 245/45/18
125amp alt with rewire
Homelink mirror
Did an SIP, FP, seal and wax on the exterior
The power outlets in the console
Projector headlights, BMW drivign lights instead of fogs with HID bulbs.
Viper 5901 1 mile remote starter/alarm installed
Then a turkey came out and wiped out the mirror on the driverside
Fixed that
Put on winter tires at the right times
Trans was built and installed at 186K miles
Engine hung a valve around 205K and was replaced with an NA motor
LED lighting throughout the entire car
Nice buick trunk liner (heavy plastic)
Recently I decided to change up the shifter. Grabbed a Caddy shifter, pulled out the welder, cutting tools and started fabbing. Need to finish it up, here's the current status.
Stay tuned
Sludge? What is it & where/how exactly did you put it in the door? I noticed the previous owner to me put loads of styrofoam in the doors for sound. Sounds good but I hear that styrofoam squeak now & again.
SecondSkinAudio.com sells a spray called Spectrum and with an additive it turns into a peanut butter thickness. I spread it with my hands. :th_peaceout:
I picked this car up almost to the day ... three years ago. I think it was May 5, 2010. Bought it at 160,xxx and currently have 216,xxx.
I'll try and list all the mods:
Drivetrain
L26 50K miles put in at 215K
4" intake with K&N
Braided fuel lines
Poly front mounts
Perf trans installed at 186k
125A Alternator
Alt rewire
Wideband O2
Plog
3" DP into GP dual exhaust
High flow bullet catalytic
ZZP aluminum trans pan
F body calipers
R1 concepts front rotors and pads
Rear knuckles and brakes from 08 GP (Ebrake in caliper)
Braided brake lines
Suspension
Aluminum subframe
Vogtland springs
Anti Pogo washers
Rear STB (front was stock)
GMPP sways front and back
Energy suspension urethane bushings and endlinks on sways
Moog rear end links
18" Lucerne wheels
Bridgestone tires
HT Motorsports (westshorefabricators.com) tubular, greaseable and urethane bushing rear trailing, toe and drag arms.
Not really mods: control arms were new, GR2 struts were new, strut mounts were new, one new wheel bearing (moog) in front and both in rear (SKF)
Black McGard lug nuts
Interior:
HUD
Door lights (on door, 2000+ GM stopped putting them in, I added them back)
Pioneer AVH- BT3200P HU (DVD) Modded for a USB out the back. This gives me hidden iPod in the center cubby
Phone dock (since it has been retired)
Homelink mirror (Maxima Murano)
Boston Acoustic speakers and crossovers, plus 10" BA sub
Boston Acoustic 5 channel amp. Mounted upside down on rear deck lid
Wiring KnuConceptz 3 sets of RCS'a, 80 feet of their speaker wire, and amp kit
SecondSkinAudio matting throughout car, sludge in doors and trunk lid
Carpet power washed and from a different car
Headliner from a different car
All bulbs are LED
Intrigue/Aurora power outlets added to console
All window regulators removed and lubed
Tint 35%
Custom box for sub
Fixed cupholder
Heated seats (GP elements, stock Regal switches)
Gated shifter
sub control in console cubby (totally hidden)
Viper 5901 1 mile remote start/alarm
Soon to add the autodown windows (for Viper)
Exterior:
BMW driving lights instead of fogs
Projector headlights (projectors from RX330)
LED bulbs in almost everything
LED turn signals behind mirrors
Sequential turn/stop signals
Dual GTP exhasut and SLP fasicas
Pretty sure I forgot a bunch of stuff.
At this point I have 56K on most of the stuff and it's all doing extermely well. The brakes are holding up amazingly, wheel bearings etc etc have all been good. Most of the time I just drive.
no not at all, i would put you on my car anytime. lol Its the hud switch in the ashtray. Damn think irks me. You know everything and take the easy way out on the switch? C'mon lol
Great looking Buick. Curious as to how you modded the head unit to have the USB out of the back? ( I have the same HU and the wire out the front annoys me.)
With the cubby door closed, it's hidden. Doesn't fit into the dash and in a nicer car like the Regal, there's no need to have something you don't need to be visible.
That was a great thread. I've seen firsthand all the work that went into the car and can say that I was impressed. I liked the way that all the mods were made to look like they came from the Factory. Oh, and the brakes...they were....okay I guess. :th_nanana: Hahahahaha!!!
Well I'm completely with you on the annoyance, the Regal has a huge cubby area right below the HU/HVAC. First you hit the store and buy a big ole can of courage and a USB cable extension. You cut the non-used (male) end off the cable and grab the radio out of the car. Open up the cover and pop the face off. IIRC this was the hardest part and I think I found a google post by a guy that did the same thing which confirmed it for me. Find a good hole in the back of the radio to feed the cable in then strip the cable and the four wires. I used a multimeter to confirm which wire was in which position and then soldered the wire to the dot on the backside of the front panel usb.
See the bracket that is kinda bent up. IIRC that was in the way and needed to be bent to solder, then bent back down. I was gentle yet firm. :th_peaceout:
Oh..BTW..the custom sub box. I made sure I left the ability to hook/unhook the cargo net.
