Booba5185
Re: 2000 GTP: I Can Jump Myself!
I only have 2 pics from the install, but there's videos on youtube if you are really interested in it. This is how far I tore the compressor down to:
This is how I ended up pressing the new coil on. Heating it up got it about 70% of the way on there, so I knew it was on there straight (not bound up). I probably would still heat it first just to make sure it's started on there correctly. 200*F for 20 minutes. It's ceramic so don't hit it was a hammer. If you choose to still want to hit something, use a flat blade on the INSIDE of the coil, it's metal and not ceramic.
Also Make sure the plug for the coil is point right about 2:00. The case of the compressor has a little bit of a relief for the coil's connector. When putting the pulley on, if the coil isn't pressed all the way on the pulley won't go on all the way. If you clean the compressor with a scotch brite pad or some sand paper, the pulley will slide right on. No not for it. If anything, heat it up a bit too (200*F for 15 minutes). If the pulley isn't going on, chances are you don't have the coil on all the way, and if you hammer on the pulley to try and get it on there more, you'll crack or break the ceramic (the pulley will be hitting the ceramic). I ended up with about .040" of air gap, and it worked great.
