Booba5185
Re: 2000 GTP...and so it begins...(LOTS of PICS)
Started building a relay harness for my headlights, but had to stop because GM headlight plugs are a PITA to disassemble. I'm going to go get some Ford plugs tomorrow from a parts truck and finish the harness then. I've got 10 AWG wire for the power to the relays and to the first headlight, then 12 AWG from there. Either way, It's over kill:
I'm building the harness to be easily removable, so if I'm on a road trip or something and it stop working, I can put the car back to stock to get along. I took an old 9007 bulb, broke the glass part off, and soldered 2 wires to the high\low pins of the bulb housing, then filled it with RTV since I ran out of Epoxy. That way I can just simply unplug the harness and plug the stock harness back into the bulb if something goes wrong with the relays. Here's a diagram I put together for FTC when I helped a friend do the conversion on his truck.
BTW, electrolysis write-up is still happening here in a few days. I needed something to clean the rust off of and I have something now...
