I feel (literally) that I have the same issue.
Background:
98 GP GT
140K
no mods under hood
never had tranny fluid touched before my filter/lube change about 3 week ago
tranny sliped after red line from first to second before change
Issue:
Changed tranny fluid and filter. Everything seemed to be running same/better after change. Drove about 250 miles on car through hills with lots of downshifting, everything ran smoothly.
Got home from trip drove to work, everything fine. Left work later on that day (about 83 degrees out) got almost home (about 10 miles), and WHAM between first and WHAM between second. Hmm, that's not good.
Summary of issue:
Car runs fine when cold, get's hot and will run good for about 10-15 miles, starts to shift hard between 1 and 2
However, if I shut the car off, let it sit for >30 seconds, car shifts fine for about 4-5 miles.... Wierd right??
Has anyone heard of this? Is it possible that when I dropped the pan Mr.Computer did a back flip? I understand there are GM software upgrades, any idea on cost? Is it probable to think I screwed up the oil change? I added 8 quarts of Dextron III oil, and about 1/2 quart of some additive (after this problem started, and it did extend the time till hard shift). Level looks good, when checking warm the fluid comes up to the criss-crossed lines on dip stick (am I reading the dipstick wrong?). BTW, I took out a little less than 8 quarts from car.
However, I should mention that I do see bubbles on dipstick when car is hot? Am I over filled even though the dipstick says I'm not?
Addition: have been reading through some other threads, just un hooked ground wire to battery (computer issue?). Also, got some advice from a friendly co-worker that there may be some blockage creating the back pressure. Would a flush be a good start?
Thanks for your help, hope I was descriptive enough.
