2000 gp turbo new pcm location?
Wbody store sells PCM trays too, but it would probably be better to get it away from the high temps of the turbo.
You could try a turbo blanket.
double sided tape to the inner fender, but if you want it to look trick i moved my pcm and fuse block to the glove box it cleans up the engine bay nice but is alot of work
The pcm tray is a little bulky for my setup, its a great solution tho. Before this i just stuck the pcm to the flatspot with some spray foam insulation. Im going to use a combination of what you guys said and extend the wires mounting the pcm verticaly on the inner frame/ fender. Itll involve moving some air con pipe over, then maybe a sheet metal heat shield, heat wrap, and a couple screws. Thanks guys!
I was unable to use the stock location due to the Turbo when mounted literally sat on top of the wires. I placed the PCM between the front bumper and fender. There are pics in my build thread.
