1998 GTP noise
Eric Whitter
when I read the motor it sounds good until I get a little bit past 3000 RP M's I can hear a really fast chattering noise it's getting me creeped out in snot an exhaust leak but the oil seems thin could it be that or not because it doesn't do it Intel around 3000 RP M's
There's a 3/16 allen wrench plug on the snout (atleast i think its a 3/16) pull it off and the fluid should be pretty dang close if not at the bottom of the threads from the plug. Otherwise thats the only fluid in the charger. Easiest method if u think its the s/c is to pull the supercharger belt off and run it and see if the sound goes away. If it does its prolly s/c coupler and zzp sells a really good one
Supercharger coupler usually is only noisy at idle, and its not really a ticking noise.
Sent from my Droid
