Nchristopherson
Price: $1500 OBO, open to negotiations
Hey everyone. This car has been sitting on my stepdad's property for a while and I am finally moving into my own apartment and have no room for this car and no time to get it back to a running state. As the title says, this car is a roller. All the pieces for a running car are there/should be there, and if not, I will check my stuff for the missing part. No guarantees but I'll work with you. Please understand, this car will require a fair amount of work to get back to a condition that is worthy of running well. It originally came apart because I was going to swap the motor into my 02 GT, but I went turbo instead. Engine ran strong before it was pulled and just needed a tune.
Notable inclusions:
- SD Headers with double wall flex pipe
- VS Cam shaft (Original cam included)
- All hardware necessary for a cam swap installed
* 90# Valve springs
* New viton valve seals
* New LIM gasket
* New front cover gasket
- Has modular pulley system and 3.4" pulley
Things to be aware of
- Braking and suspension
* Check ball joints and tie rods
* Struts were recently replaced but seem to be going bad already
* Check the master cylinder
* Check brake calipers
* Tires are old and need to be replaced
- The engine
* needs oil
* Check front cover gasket
* Harmonic balancer needs to be attached
- The trans
* Need fluid (included)
* Needs filter and bushing installed (included)
* Check pan bolts and add remaining pan bolts
* I believe the TCC solenoid needs to be replaced. Car would randomly shut down when first starting and driving, then never do it again fro the rest of the drive.
- Drivetrain
* Flywheel and torque converter need to be bolted together
* Need an axle nut
* Passenger side axle needs to be reground/rethreaded or replaced
- Cooling
* The radiator needs to be replaced (included)
- Exterior
* The blue bumper attached is NOT included. I couldn't fit the blue one around my IC piping and didn't wanna sacrifice the fogs, so I'm using the unpainted cover that was originally on this car.
Pictures are here: https://drive.google.com/open?id=0BzVFuTcJenYqSXpRMVdNNlltNk0
Unfortunately it's cumbersome to upload pictures and I don't have a photobucket, so I'll just do that.
Notable inclusions:
* 90# Valve springs
* New LIM gasket
- The engine
* needs oil
- The trans
- Drivetrain
* Need an axle nut
- Cooling
- Exterior
