1997 GP GT Fuse Box Schematics Request
Melancholy43920
OK my very first post on here...where to start...
I've been dealing with an electrical gremlin for some time now. I finally got myself a nice multimeter so I could find the source of my parasitic drain. With everything shut off I was pulling 90mA so I started pulling fuses. I finally found the culprit at #29 under the hood which is only marked 'Radio (10)'. Well when I started up my car with this fuse pulled not only did I not have radio but I also had no dash CPU, no ABS and no TCS so it's quite apparent that fuse controls much more than just the radio as it lists.
What I need is a wiring schematic that covers the fuse box under the hood, and specifically the #29 Radio (10) fuse so that I can figure out everything that is being run under this one fuse and how to disconnect each accessory individually to isolate my parasitic draw. When I pulled that fuse the meter dropped from .090 amps to .002 amps so I know it's something on that circuit. Thanks in advance.
What you ask is hard to find. I'd have to go through every single wiring diagram for the car in the GM manual looking for that fuse to be included to know what else runs off of it. That's like a hundred or more. I'm sorry, I don't have that kind of free time.
Hey, I found some I can send off to you, I sent a PM and anyone else who may need these let me know and I can send em.
Hey I have a 98 grandprix gt with the same problem! Could I could a copy of the schematics. OP were you able to figure out what caused your draw yet?? Might be the same on mine.
