the reason people use the colder t stats is to fool the computer into staying in cold start mode (bypassing o2 sensors) making it dump more gas.
That's what a 160* tstat does. 180* tstat will let it warm up enough.
but your statement a cooler engine makes more power is what I am referring to, when my car had a 180 in it (when I bought it) it would not get to 200* and ran poorly (gas mileage was at about 18 mpg) replace the t stat with a 190 and get better acceleration, and currently am seeing just under 25mpg. The internal combustion engine needs heat to work properly
I'm confused then. What's the point of a 180* tstat if the computer is no longer in warm up mode but it doesn't get hot enough to make power?
so are u sayin the tstat takes away from your mpg?i just bought one so if thats the case im not puttin it on.
It is true it takes away MPG. I knew that going in, but if there's no other benefit then screw it.
but if theres no benefits why u put it in?
