18" wheels comments
Egleone6
What do you think? They are off the Solstice.
youre going to want to look at a 5x115 or 5x114.3 bolt pattern with an offset somewhere in the high 30s.
yeah look, don't get tricked if it says universal 5 lug you still need to make sure it has the proper lug pattern which is 5x115 with an offset about 35 give or take, you could also go 5x114.3 but it is best to either egg out the lugs or get a lug adaptor first. And most importantly try them on first make sure the tires don't scrape the fender when you turn, a slight problem could very easily turn into a very big one. In addition if you notice a wobbly ride be sure to pick up wheel spacers to go over the lug you can pick them up for only $40 bucks a set
