Tuner-Extraordinaire
180, no lower.
Lol well even so. Opinion is invalid for replying like a 13yr old teeny bopper
Thermostat upgrades will benefit or hurt depending on your climate.
For example: if you live in the northern states I'd imagine that this mod would not be helpful really do to the temperatures.
-I've seen this mod reduce kr. I agree, do NOT depend on this mod alone to reduce yours. But if your car isn't prone to KR then I wouldn't worry about it.
In other words its very circumstantial. Scan your car first.
←Android→
Why aren't you supposed to go beating on a car before it gets up to temp? Same reason.
Cold rotating assembly doesn't like to be hammered on.
How does decreasing the thermal range your motor normally sees, increase wear on your motor. Seems opposite to me.
Because your knock sensor isn't on until engine is up to 160*. How is 180* "cold"?
M90 is especially known for heat seeing as the cars they were put on did not come factory with their own heat exchangers and intercoolers like the LSJ or LNF.
Any cooling mods that you can do, that wont over work your systems, is beneficial if you're looking to make more power.
←Android→
Temperature inside the combustion chamber is the same, but water temp is lower, resulting in an increased thermal stress gradient.
One of the "oil impurities" is water.
Which doesn't boil until 212* F.
Oil needs to reach that temperature.
