Z34Phoenix
Florida Tuner
Ok im just about done porting my heads for the topswap and am looking to start assembling them soon. I have a set of 105 # springs but unsure if is should use them or the stock springs. here is what will be installed and total mods:
L36
Gen 3 with mild porting, 3.8"
High velocity TB
Ported heads. referenced photos of stage 3 heads while porting. port and valve diameter are stock. port shape nicely tweaked, chamber smoothed and clearanced for the valves.
Si Valves
SLP 1.8 aluminum roller rockers
Speed Daddy headers
3" high flow cat
2.5" cat back
I guess the main question is... are the 105's needed at all for my setup? i no longer think i will be revving the engine out high in the rpm band. the other factors in my head are that the member i purchased the springs from did not know the brand of them. i know there were bad batches of springs that were cracking... adding to that is the fact that all the Si valves that broke were due to heavier springs. now i have read that they are rated for 115 # springs or less and mentioned that 90# yellow springs caused failures due to the high ramp rate on them. my thinking is if the springs aren't needed for my setup then i will just go with stock springs which are more reliable and safer for the Si valves.
ok input/ advice time.
L36
High velocity TB
Si Valves
Speed Daddy headers
3" high flow cat
2.5" cat back
