could you explain more in depth. im a noob when it comes to these numbers. why would my trap go down if im able to keep traction off the line? would i not be gaining speed faster? thus giving me a much better 1/4 time?
i just looked in my wheel well, its coated with rubber from my tires![]()
More like some slicks and you will be golden.gotcha, thank you for the info. basically i need suspension, good tires, and driver mod.
Please explain how a better launch will result in trap speed going down.If you get off the line faster your trap speed could potentially go down.
I already did. Read post 22.
?Higher traps doesn't always equal faster ET's. I have seen this happen time and time again, from personal experience and being around cars forever.
Think about this.
If you spin to the 300' mark then gain traction your speed may get up to 45 mph and then increase from there. The loss of traction killed your ET, but your trap was higher.
If you gain traction on the launch you may only be at 40 mph at the 300' mark, but once you cross the finish you will have inpmroved your ET, but your speed won't be as high.
When it comes to drag racing your ET is gained or loss in the first 60'.
