3 times in 2 days, on start up, I would get 3 warnings. ABS failure, Traction controlfailure,and Variable effort Steering failure. Upon restart,it would be fine. The 4th time I could not "reset" it. The steering is noticably not working right, and the traction control and ABS are all non-functional.
If it was a fuse........the problem would not have "reset 3 times previous to failure.
Ruling out fuse.
Im thinking an encoder on one of the front wheels. An encoder there, I would think, would need to communicate with all 3 of those systems to function properly, resulting in all 3 failures being reported at the same time.
I would guess a "no signal" from the encoder, the computer will abort all systems downstream of that sensor.
Am I going down the right path here?
Thanks...Gary
Ruling out fuse.
Thanks...Gary
