And you ARE right about the table to turn fans off because of AC. But it is set at 75 mph and only turns off if ac pressure is high...or low. I don't know exactly what the conditions mean because I don't know a lot about the ac system...so many variables with it.
I would venture a guess that ect tables override this ac condition. Could be wrong but I would imagine keeping the ect's in check takes precedence over the ac fan control table.
I would agree with that completely. If you had low coolant or some other need like towing where your loading the system down at highway speed you would always have that over ride to keep temps in check.
regarding the description of the fans shutting off if high or low pressure is detected would probably be due to at 75 your RPMs are high enough that if the system is overfilled it could trip the high pressure switch, and if the low pressure switch is tripped then it's probably shutting down the AC clutch as well as it normally would. Usually the fans won't run if the compressor doesn't run. That would be my guess. I still think that 05' tables are a lot different as far as when it shuts the fans off. Scotty?
