monkeydude3602000
First post here. I recently picked up a 04 grand prix gt as a work car. Wasn't necessarily planning on doing anything to the car other than general upkeep and window tint. It's got a bit over 250k on it but surprising enough it's one of the nicest driving and problem free vehicles I've ever owned. Interior is very nice and body is straight just paint flaking on the plastic parts. Steering is super tight. No noises. No lights on the dash. Even had new tires. So far I've put 5k on it and besides coolant elbows, rear window regs, and the blower resistor it's gave me no serious issues whatsoever. This car had excellent service records and I'm the 3rd owner. So down to business. I started researching the top swap and I was hooked. I've always wanted a gtp and now I'm about to make my own.
I scored a killer deal on a complete series II top end. A set of heads, LIM, 3 that's right 3 Gen3 m90s, 3 sets of fuel rails and injectors (one set cleaned with new o rings), 3 TBs (even though I can't use them) most of the bolts, bracketry, pulley stuff, all except for balancer and crank pulley, an extra water pump, oil filter housing, several extra odds and ins, but here's the icing on the cake... a new set of headbolts and a complete unopened top end gasket kit. All of this for $200. Guy rounded all this up for a 97 gt top swap then some old broad totaled his car. Still can't believe he didn't want more.
The heads will be sent to a machine shop to be cleaned and checked and get a valve job. Contemplating on zzp titanium valves and most likely springs too as I plan to use zzp 1.9 rockers to hopefully help with kr and get a little more air moving. I will probably go with the #90 springs unless someone has a better suggestion.
Cam will remain stock. Timing set may possibly be replaced. Suggestions here?
I've selected the best blower. It is very clean (other guy had already cleaned it up and polished the rotors) it only needs a coupler which I'm going to take from one of the spare blowers. I may do some slight port work on the intake side. And I wouldn't mind blocking off the silencer holes too. I'm buying the modular pulley kit as well along with a new belt.
I'm going to use a zzp front power log and downpipe but that's all for now. 3" or 2.5" on the dp? I'd rather go 3 if it won't hurt me to leave room for improvement. I'll build a homemade CAI. Or possibly try to buy my buddies wizard intake off his gtp as he's thinking of changing it.
As for tuning I will be using a aem wide band, aero force scan guage to monitor KR and Trans temp and HP Tuners for tuning. Fortunately I have lots of friends including my boss that's very handy with setting up fuel maps and timing. And a local dyno.
Just for peace of mind I'll probably change the trans fluid and filter and add an external cooler. Car already has a 180 tstat. Going to stick with that and see how it works. The entire cooling system is new (previous owner couldn't figure out the elbows lol) but I'll probably give it a good flush.
So here's a few more questions... and yes I've read the write ups I'm just a bit unclear on a few things.
What's involved with using a 2 bar map with my stock ecm? Can it be programmed with HP tuners?
Does a 3.5 pulley sound like a safe starting point?
What are my throttle body options for an 04 GT? Pretty sure it's drive by wire. I want to do anything within reason to reduce KR. Will the stocker suffice? Will a same year gtp tb work?
Does this sound like a good build plan? Lots of reading I know but if you made it this far thanks for any advice in advance.
