+04 rubber key guard dash thingy
Jake U
Ok I have been missing the little rubber key guard thing that inserts into my dash panel and I was wondering if anybody would know the actual name or a part number for that piece. I am going to the dealership to get a new idler pulley and was wanting to order that rubber guard while I'm at it. If anybody could help me out, that would be great
one if ur not wanting to get rapped o'riellys and auto zone have the tensioner assembly and two give me a little bit ill go see if mine has a number on it
Ok. I would go that route but I live in an apartment and have no garage to work on my car especially when its 5 degrees out. And thanks for checking your dash piece.
where did you get ur head lights???
I got them off of Carid.com. I would not buy them because they were horrible. I actually have my stock lights in my car now with 55w HIDs. My reflector is starting to have a burnt look right next to the bulb so I am going to have classy pontiac whip me up some retros when I get my tax return and run some 35w in the projector and move my 55w to bright housing.
still man i paid like 100 for a gm tensioner assembly from auto zone took me an hour tops to do it all you have to do is remove the altenator three bolts old coolant elbows (it comes with new ones) i had aluminum ones i put in instead and revearse for the new one
I guess I will look at it again to see if I can get it done myself. Hell if i can swap PCMs in my dark underground parking lot I could probably handle a few bolts.
dude its a cake walk it really is basic set of tools gets it done dont forget some rtv probubly go red rtv i think thats the heat one and the rubber guard the numbers i found on it appear as such E/P.PP CAV 4
4777
If you can't find the rubber thing I spent 15 minutes at the JY and they let me have it for a buck... Just option #2 if you need it
