Bandit1228
Its been a while since I’ve posted anything since I haven’t had much time to do anything with my
04 GTP. My car has been sitting in the driveway for the past several (6-9) months and I’ve been
starting it to let it run for a while to keep all of the fluids flowing and to keep the battery charged.
Here’s the order of events of my current issue.
1. Started car and it ran for 2-3 minutes
2. Noticed weird odor while I was walking around car. Almost like burning rubber or electrical wire. At first I chalked it up to the new catalytic I installed but I think it was something else under the hood. Never found cause of
odor.
3. Car stalled.
4. Noticed message on DIC ..CHARGING SYSTEM FAILURE
5. Car will not start. Car will not even crank. Do not hear fuel pump prime and no fuel
pressure
6. Attempted to jump start and also eventually replaced the battery and still no crank.
(Battery is good)
7. Removed crank relay and used jumper wire in place of relay and starter would crank.
(Starter is good)
8. Removed belts and put wrench of crank and was able to turn crank so I'm assuming it's not seized.
Does anyone have a suggestion to what the next step would be to check? I’m not sure why it
stalled and suddenly now it won’t even crank. Would this be an issue with the ignition?
odor.
3. Car stalled.
pressure
(Battery is good)
(Starter is good)
