04 gtp cylinder #3 missfire
BAD BAd news today boys!!!!!!!!!!!!!!!!!! compession test done today 3-4 low on compression!!!!!!!!!!!!!!!!!!!!!!!!! barley gettin to 100.. Now i need some really good advice its at least 1,500 to tear down and rebuild, but then i no what i have, or 1,500- 1,700 for a junk yard one with 70-140,000 on it, or 2,500 for a rebuilt i think? Plus my tranny has a little clunk in it so as long as its comin out either rebuild or replace, were talking almost 3,000 by the time im done. Ne ideas on which way to go or what to do here??? Please let me know. I'm reaady to say bye bye to it. But please everyone what ya think or what should i do for each thing here??????
find a used engine, and tranny if you can. cl part outs are a great place to find stuff. or junk yards.
if a l67 is not to be found, you could get a n/a engine and top swap it with your parts if the heads are not damaged.
no way id be rebuilding for those prices. used works out most of the time. some have had bad luck tho.
a used motor and tranny could be 1000 or less. if your installing it, if you have to pull it out of a parts car, the price could also drop.
oh i forgot to add, you dont "have" to find a l32, a l67 will work, swap your lim and blower, fuel rails, and injectors on the donor engine and let it rip.
L26 = 04+ Series III Block Naturally Aspirated
L36 = 97-03 Series II Block Naturally Aspirated
L32 = 04+ Series III Block w/ Gen V Eaton M90 Blower
L67 = 97-03 Series II Block w/ Gen III Eaton M90 Blower
Advice has already been given to you. Locate a used engine and transmission. I have seen combos sold for ~$1000-1500 dollars.
If you go that route, replace fluids, do tune up, replace LIM gaskets if not already done, and foremost.....
RUN AT LEAST 91+ OCTANE FUEL!
You can source out your out your own parts. We are not here to hold your hand, only to point you in the right direction.
On the brighter side... it might not actually be an internal transmission problem.
You have not described the problem in full detail... when it happens, what it sounds like, and so on.
It could be anything from a busted sway bar link, bushing shot, ball joint toasted, engine mount gone, strut mount trashed.
dont wanna have to swap all that stuff want to keep it as simple as possible have way to much into this thing already. how do i know what i have for a tranny i guess there are 2 diff options? 2.93 fr2 or 3.29 fr9?? which one is better also?
thats all either been changed or checked already. When i go from forward to reverse and give it a little gas there is a little bang in front right side when its up in the air u can feel it in the tranny and also see the pass side cv shaft shift very slightly.. Also just put in a new shaft.
as per your looking for a engine thread, if you have a comp g, you need a comp G trans, thats gonna be a bit harder to find, and cost more.
and what is the trans doing? why toss money at something when your not 100% sure whats going on?
you need motor mounts i bet, the engine and tranny will move forward and back inches when they are shot, and clunk hard when put into gear.
I believe I read somewhere you have a Comp-G... which has 3.29 gear.
There is no "better" gear.
3.29 gears are designed to have higher acceleration, but lower top speeds. This also affects fuel mileage negatively.
Like I said we do not hold your hand. It is your vehicle; your responsibility to make those calls. We all have repetitively stated just buy a junkyard motor.
And why do you say you don't want to go through the hassle of swapping everything out, when you so eagerly want to take the engine to a machine shop? You do know they can't rebuild your engine inside the vehicle right?
You want to sell it, I'll give you $1500 for it.
yes i know that, i dont want someone holding my hand just looking for good advice and wanna make sure its done right just stuck 2,000 into it, and now all this, so kinda skeptic on doin ne more. No its booked at 7,000 or higher doesnt show a comp g price, and runs, so no way. And i dont wanna have to buy all that different stuff when i have all the stuff i need to make the right engine work.. Where is a good place to look for engines and trannys i looked on car part.com anywhere else got good deals yards around here are expensive
ok thanks not rel sure on what all that is im not as big into these as you guys are so i might sound kinds atupid sometimes.. like the lim gaskets? all i know is intake gaskets and stuff like that not all that other terminology sorry?? dont mean to be tarded.. another thing i forgot to say is when he was doin the compression test he said that at idle up to almost 2,000 rpm it had a hard time hittin 100 but around 2,000 and up it was fine? So might this be somethin diff??
