Mr D
lol--spent several hrs crawling on cold a$$ concrete slab underneath mine this weekend, I need a few days before I get back to it, too.
Again, thanks to all who contributed! Really, I feel like I have a handle on what needs to be done, but without shared experience/knowledge I would still be swinging in the dark, more like pissing in the wind, or taking it up the rear from a mechanic (GM dealer charges $140/hr). All hubs have tested good.
I'm not a mechanic or electrician, but this is my take... Mainjet and Brandon are both right.
Mainjet, its awesome your systems are working again, but seems very unlikely that anything was "fixed". I'm not good person to tell others what they should do, but mainjet, I would consider holding onto any parts you have for few weeks, I mean I would not spend the $ to ship them back just yet.
I have not had benefit of having a working system to compare against, but I believe I have multiple failures/bad parts. From what I have read, observed, & deduced, I am planning on rebuilding EBCM with mastermodule and putting in new ignition.
Link to ignition issues has good info, but mine hasn't failed when I could test fuse, but it makes sense to me. I do have a mechanic in family, and describing some of the issues I have, first thing he said was, 'bad ground' then, 'ignition can cause that', this was all prior to my joining forum.
I believe they are related. Ignition sends power all over the place, & ABS & HVAC blower are on same fuse.
In my humble opinion, limited electrical experience, a bad circuit in one system could corrupt the other. I am refraining from leaving blowing and radio on at start-up, and stopped using seat heater until I get both igniton and EBCM fixed. I think if your ignition is bad, it can cook other electrical components, so I will likely do that first.
I will post progress when I can actually get some parts installed.
