02 sensor non fouler
kurupt305
whats up so I recently put on a spark plug non fouler on my 02 sensor due to the fact I was getting the 0420 code. Everything worked fine for like two days. Seems to me that long trips ie maybe 30 minutes will trip the cel with the non fouler installed I live in Miami florida therefore im thinking the heat outside and from the engine might be tripping it? Any other suggestions on ideas that maybe I can incorporate to the non fouler thanks
Yea my nxt upgrade will be a 3.6 pulley and overkill tune I know he can block that code can I drop a 3.6 with out the pcm or do I need pcm first or do you need to buy both at same time
You need something to scan with first before you grenade your motor! You gotta see if your knocking right now on the stock pulley before you throw on a smaller one.
any good recommendations on aeroforce gauges then that is the type of gauge I need right? Don't they just plug into the obd2 connecter?
ZZP has them or search the classifieds when they pop up and you can save a few $$. And yes just plugs into the obd2 port or you can try the torque app that some guys use I'd you have a android device.
