02 Grand Prix Tranny to Bonneville
Zack
I currently have an 01Bonneville with a bad tranny and an extra transmission from a 02 grand Prix. How difficult would it be to put it in the Bonneville/what would need to be done?
Sent from my XT907 using Tapatalk 4
"Should" be a direct swap. They both should be 4T65e's and the same gear ratio.
They are both NA cars right?
Although the trans mounts might be in a different spot?
When I took a trans out a 99 bonnevile and put it in my 97 gtp I had no issues the brackets needed will bolt in the back if the trans with no issues.
just becareful.....the bonneville HAS to have the webbing in the back of the trans. if it does not have the webbing, yes it will bolt up however you crack the back of the case....
it has to look like this
6507-1997-bonneville-transmission-transwebb-jpg
not like this
6508-1997-bonneville-transmission-transwo-jpg
