Midnight Hammer
I purchased an 01 GTP 2 months ago. Motor spun a rod the SAME day I bought it. Just got done replacing the motor and power steering pump since it was whining at low speeds. Used a remanufactured unit and did the procedure to free trapped air, after I flushed about a quart or two of new fluid through the system. Seems to be working fairly well. Slight whine at low speeds and steering seems to be a little stiffer than I think it should be.
The scary part is I can be turning left in an intersection and all of the sudden it's like I just cranked the wheel an extra half turn. It's like a smooth, fluid motion but very sudden. I immediately have to compensate so I don't hit anything.
Then took a slow left curve and the same thing happened. I straightened up and then immediately got a slight movement that pulled to the right and immediately stopped.
Would this be a rack issue? Faulty PS pump?
$3k for the car. $1,500 into motor swap and all new gaskets. Still have to get a new headlight, get water out of spoiler, fix fan resistor or ignition. Not happy. Looks can deceive.
