01 gtp firing order
samuelcb409
need to know the firing order asap... changed plug wires today and now car wont start is it
front 1 5 3
rear 4 2 6
i wont to says it 123456..i thats more then likly wrong..as long as you had the right plug on the same coil as clyinder..like coil 1 to cly 1,, it should work
Firewall
2....4.....6
Engine
1....3...5
Coil packs
Top:3/6
Middle: 2/5
Bottom: 1/4
The coils fire both towers at the same time, so if you put the 4 and 1 wires on either of the bottom coils posts...you are all set.
its running sluggish, and misfire at idle was noticeable and could here it in the exhaust, also when driving on highway felt it misfire when going over under pass or a bridge, full throttle wasn't normal either.
Check your new coils for cracks. This exact thing happened to me after 3k miles on new coils. I threw in lower mileage stock junkyard ones, been fine ever since.
