00' GP GT Stalling issues
Nix
So I was given this GP because the owner didn't want to fix it.
Hot or cold start has the same result the car will start and run fine for 30 second rev high and then stall. This happens in idle or while driving. (riding the fuel pedal will keep the car running, with no shaking or other abnormalities other then the high rev from adding pressure to the fuel pedal.)
I have tried running it with bank 1 o2 unplugged with no difference.
I have tried running it with the MAF sensor unplugged with no difference.
I have tried running it with the fuel relay bypassed with no difference.
I was told the car had plugs and cables were replaced a few months back with the battery.
I have just replaced the crank sensor with no difference.
Maybe someone has had this issue once and could add a bit of knowledge.
No codes are lighting up. The trac/abs light are on but not the check eng/service eng lights. All light work at key turn.
S.O. a B. should have tried that earlier, I just didn't think about it.
*that's my problem* Thanks man.:th_thumb-up:
Eagan, MN
I was just given the car a few days ago when they bought a new acadia
So fixing it for $20 while they spend $25,000 on a new one is good for me.
Hopefully this thread will help others with unsolved stalling issues.
