Thread: Rearview mirror temp displays "sc"
Results 1 to 4 of 4
  1. #1 Rearview mirror temp displays "sc"
    SE Level Member trey9778's Avatar
    May 2013
    Orlando, Fl
    My rearview mirror displays "sc" in the outside temp spot. I replaced the ambient temp sensor located behind the front bumper with part# SU1340 from autozone. I disconnected the battery during the installation process and unplugged the mirror prior to starting the car after re-connecting the battery and it still says "sc". Any ideas anyone?
  2. #2 Re: Rearview mirror temp displays "sc"
    Would help if we knew what you drive.
  3. #3 Re: Rearview mirror temp displays "sc"
    May 2013
    Orlando, Fl
    2002 gtp with the onstar mirror
  4. #4 Re: Rearview mirror temp displays "sc"
    May 2013
    Orlando, Fl
    I found the problem. There was a green wire grounding out under the battery. Whoever had the car before me must have put the battery on the wire and moved it around creating a hole in the insulation causing it to ground out.
  1. 2006 Grand Prix "Reduced Engine Power" and "Service Traction System" warnings
    By chadwick in forum General Grand Prix Discussion
    Last Post: 10-04-2013, 09:59 PM
  2. quick question... is this the "temp sensor" on 95' gtp (pic included)
    By Falcons33 in forum General Tech Discussion
    Last Post: 04-23-2013, 05:41 PM
  3. Replies: 2
    Last Post: 04-25-2011, 06:37 PM
  4. How do i add a temp/compass rearview mirror?
    By themagicdustman in forum Audio, Security & Visual Electronics
    Last Post: 04-02-2010, 01:46 AM
  5. Rearview mirror displays "ICE"... Never happend before
    By Freebeer187 in forum General Tech Discussion
    Last Post: 12-16-2008, 08:31 PM
