Thread: Blend Door Actuator Replacement
Page 5 of 5 FirstFirst ... 345
Results 81 to 90 of 90
  1. #81 Re: Blend Door Actuator Replacement
    GTX Level Member SomeDudeAtHome's Avatar
    Buffalo, NY
    So the vents on the drivers side blow hot while the passenger side blow cold. Common sense tells me that the drivers side needs replacing but common sense isn't always the way things work with these cars. Also is it the same part for both driver and passenger side or are they different. I'm only seeing one part listed on Rockauto. Figure I might as well replace both of them while I'm at it.
    Black 98 GT bought in summer of 2009 w/28K miles- GTX Rims, Retrofit headlights, tinted tails, 20% tint all around, KYB Excel-G's, WBS Lowering Springs, 33mm Dorman front sway bar, 22mm Addco rear sway bar, BMR trailing arms, BMR STBs front and rear, ZZP control arms, Poly motor mounts, ZZP CAI, Thrasher shift kit
  2. #82 Re: Blend Door Actuator Replacement
    Ohio
    For those of you with dual climate blowing hot on the drivers side/cool on the passenger side: did you replace both sides? I replaced the driver's side, and the air is cooler now but not as cool as the passenger side. Do I need to do passenger as well?
  3. #83 Re: Blend Door Actuator Replacement
    if its not as cold on the driver side you might need a re charge.
    you can take the actuator back off turn the knob by hand to see if its blows full cold as well. thats a free test at least.
  4. #84 Re: Blend Door Actuator Replacement
    Ohio
    It's free to try, but man I don't want to take that thing back off. I was all twisted up laying on my back with my head down by the pedals. Bloodied up both hands trying to get to it.
    Thanks Scotty
  5. #85 Re: Blend Door Actuator Replacement
    i feel your pain, mines only held on with one little bolt now lol
    and i wear size 3x gloves too. dont help any.
  6. #86 Re: Blend Door Actuator Replacement
    GTP Level Member
    Oct 2011
    Raleigh, NC
    Where is the blend door temp actuator for single zone manual control for the 1997 GTP ?
    1997 Red GTP 182000 miles stock
  7. #87 Re: Blend Door Actuator Replacement
    GTP Level Member
    Oct 2011
    Raleigh, NC
    Has anyone tried this method ?
    Quote Originally Posted by Kscottm View Post
    A helpful tip when pulling out that drivers side actuator (97-03). After removing the carpeted board above the pedals and the plastic panel below the steering wheel, pull off the black metal bracket the aforementioned plastic piece was attached to (four bolts and a couple screws). This gives you a straight shot to the LH blend actuator (I'm 6'5" with big hands and was able to get in there with little issue). Use a 7/32" deep socket to remove the three small bolts from the actuator and unplug (no extension or ratchet required). Once panels are out, should only take a couple minutes to pull the actuator! Hope this helps...
  8. #88 Re: Blend Door Actuator Replacement
    i took all that off, all it did was let me see the actuator while peeking through the crack, lets you find the little bolts easier, thats for sure.
  9. #89 Re: Blend Door Actuator Replacement
    GTP Level Member
    Oct 2011
    Raleigh, NC
    thanks, does it matter if the tilt wheel is up or down ?
    Does this mean the actuator is close to the steering column ?
    I thought it was by the center console above the gas pedal ?
    Anyone have a picture or video ?
  10. #90 Re: Blend Door Actuator Replacement
    http://www.grandprixforums.net/threa...or-Replacement lets read page one, post one.....
  1. Blend door
    By BADAZGTP in forum General Tech Discussion
    Last Post: 06-27-2016, 02:25 AM
  2. Blend Door
    By 98GTPON22s in forum General Tech Discussion
    Last Post: 03-07-2012, 09:50 PM
  3. Temperature Actuator
    By s7falcon in forum Shops and Community Heroes
    Last Post: 09-04-2009, 11:36 AM
  4. 97 grand prix gt 3.8 liter ac blend door actuator
    By king1997 in forum General Tech Discussion
    Last Post: 06-18-2009, 07:58 PM
  5. Throttle Actuator
    By chrisothoulos in forum General Tech Discussion
    Last Post: 05-22-2009, 03:56 PM
