wel i havent seen it yet, but i got a call from my mother that it came in on the pallet that the seller shipped it on. its sitting in my garage now still wrapped up. im awaiting from another seller that i bought a new ZZP tranny filter that i'll swap into the tranny as well as drain the fluid in there so the shop that im getting it done can put in new Dextron 3. the tranny has 4K-5K miles on it and the previous owner said he went 12.4@114mph. heres the specs on the tranny:
Dynotech level III (750hp) 1997 4t65E-HD
Complete Overhaul Kit - Includes all new paper, rubber, Teflon, metal clad seals, and all necessary bushings.
Borg Warner Bands & Clutches
Dynotech Custom Clutch Packs - Custom stacking and configuration for the forward, 2nd, 3rd, and 4th clutch packs
4th Gear hardened clutch hub
All new Solenoids
Modified Torque Converter Clutch circuit - eliminates problem with converter locking and unlocking during cruise
Late Style Valve Bodies - Rebuilt and utilize reinforced boost sleeve
Shift Kit
300M Input Shaft
Diode Sprags
Raybestos 3rd Gear Clutch Pack
GM 1" Drive Chain ratio (3.29)
ZZP 2750 Stall w/L36 Flexplate
Stock Reluctor Wheel
What do u think? I already have my bin file updated for the gear ratios as well as the min tcc apply thanks very much to eddie and his expertise. Also thanks to dave n. for helping me through with my answers on what to look and what not. Only thing waiting is the tranny filter, then I’ll do the filter swap and then schedule a time to take it to the local reputable tranny shop down the street. The mechanic quote 300-400 for the swap, that’s about right correct? He said he’ll drive the car once its complete just to get it out of the garage when its done so I can go and set the pcm for the gearing. Is it alright if he drives it a few feet or is that bad?
Onto the pics::th_drooling::burnrubber0:
All new Solenoids
Shift Kit
300M Input Shaft
Diode Sprags
