Burbman
BillBoost37 said:I think he wishes it was a little easier
BINGO...I've never had to change an axle so doing it for the first time. I'm changing both because I can't tell which side is bad, the boots look fine, no grease spraying, etc. I was on here and also Googled till my fingers hurt, the symptom of vibrates on acceleration, smooth on coasting, and gets worse accelerating into a right turn. I found a half dozen posts on various forums with that exact symptom, and the cause was the same every time: bad axle, replaced it and vibration went away...but nobody said which side!!
I'll stop overthinking this and dive into it tonight. Will follow your instructions to a tee and post back.
