What did you do to your Car today?
Status
Not open for further replies.
man ive bleed this thing for over 2 hours, ive cracked both bleeders idk how many times, if theres air in there i have no idea how
Vapor lock? Pull off your tstat and see if the LIM is full to the top with water or not. This gave me a few headaches for a while.
Remove rad cap, squeeze hoses a few times, start car, sit and watch coolant and when it drops add more. Every time it drops you are removing an huge air bubble.
Thats easier said then done, this thing is a ***** to get to
ive done that but not with it running, ive tried with the bleeders open but not with the cap off ill try that
Yeah, you have to start the car so that the water pump is moving the water throughout the system. When the air bubble gets up toward the cap area it has a large place to escape.
im gonna try that, and plus i think my temp gauge is broken, it reads at 210~ mostly goes up and down a bit but the middle is about 210
yup, well im done with thing for now, im spent the last hour bleeding it and still doing the same thing...im just gonna try again at work were i have more tools to use
Dropped the Prix off at the shop for new quick struts, alignment and an oil change tomorrow.
Hopefully no more saggy rear and all noise is eliminated and my tires are still salvageable. Hopefully.
Yeah not sure I'll put them on later tonight. I know the instructions said something about existing screw holes.
Sent using my Galaxy SIII on Tapatalk 2
Got these in :cool:
Where did you get these from could you post a link if possible please
Cleared the snow off of it and made a path so I don't have to walk through a few inches of snow to go to work on the morning.
Status
