gotspeed1212
k i know its a little off topic but it looks like you guys have a nice and knowledgeable community.
i have a 95 trasport van with the opt motor (3800)its got 98,000 miles on it now, and has started to get a slight miss in it. i would say it started last winter/spring and is now getting worse. there is kind of a sweet spot when you accelerate were it feels it has all the power it use to. but if you try to drive away from a light (like the bigger motor would :th_laugh-pointup: ) it sorta just stumbles and falls on its face. also it no longer revs past 4,200 rpm, it drops right down to 3,500 and goes back to 4,200. the redline is at 6K.
the other thing i have noticed is when your driving along at 40 mph or so and put your foot on the pedal to speed up to lets say 45 the rpm start to clime, they get to 2,500 and drop to 2,000. when i say drop its almost like the motor turns off it goes down so fast. once and a while it will shake a little when it does this.
we have a actron scaner and it shows a cyl 1 and 4 (same coil pack) miss fire at idle and when you rev it, and cyl 3 at idle miss fires. other then that it shows a code for a miss fire signal and nothing else.
if you need to know any numbers from the scanner about the motor just ask and i will get them and post
before this happened we were joking around about doing a burn out contest in this van now were joking about burning this van up.
