    TIPS:
WTS/WTT 255lph venturi pump, TOG downpipe, other header downpipes, stainless reducer
Tengis
From highflowfuel.com. I sold a ton of these before I closed down my shop.
$63 shipped
I also have a Deatsch Werks 320lph pump with install kit for sale. Normally like $150.
$110 shipped
Two stainless downpipes with flex
$35 + shipping each
TOG stainless 304 downpipe with interlocking flex
$50 + shipping
The reducer is a stainless 304 pipe with multiple sizes reducing/expanding. It is off of an expensive airbag system from a Mercedes that I bought from someone a while back to cut up and use as reducers.
$28 shipped
I will trade any of the above for a ZZP full 3" bolt in downpipe for a vehicle with stock rear manifold and stock exhaust. Im going to Japan soon which means all this stuff will be in storage otherwise. Do it for your country! ;)
WTS Turbo electronic boost controller: Greddy Profec B Spec 2
Edit: removed
Holden upper intake with 1/2" fuel rails and custom throttle body bracket
Edit: removed
Custom black ceramic coated T4 turbo kit with turbo headers
Edit: removed
I have a gen 3 blower that was rebuilt with new bearings, coupler, etc at 70k miles. It now has 105k. Make me an offer if you're interested.
Re: WTS/WTT 255lph venturi pumps, black ceramic coated T4 turbo kit, Holden upper int
Need these fuel pumps gone...
What set-ups do these Venturi pumps work with? I have a 99 gtp with stock pump tank and lines and am looking for a upgrade
They work in any canister that has an existing venturi pump in it. I believe your 99 is venturi.
It's the whole PUMP that needs to be installed into your canister.
Pictures are in the post. The DP still fit ebay headers or can be cut up for parts.
