98 GTP - Usual 3.4" setup
Alright, so I have an annoying rough idle. It's been going on for awhile now. It only does it while in Drive. Park/Neutral everything is smooth. Cold or warm doesn't matter, still does it. The car will shutter/rumble/shake almost like it is wanting to stall out but never does. When I come to a complete stop, the rpms will drop to 500-600(not every time) and then it will go back up to around 800 rpms. Now while I am sitting there at a stop, rpms will fluctuate between 600-900(again not every time) while the shuttering is going on. I can give it a little gas and it will smooth out around 1000. Going down the road she runs as smooth as could be. I haven't experienced any noticeable power loss. No check engine light or anything. It doesn't seem to get any worse or any better.
What I've done so far(not particularity to fix this problem)
MAF sensor
Autolite 104's gapped at .55
New plug wires.. think they are delco's
Cleaned out throttle body and replaced gasket
Inspected and sprayed around vacuum lines(seem fine although I may have overlooked)
I should add this problem existed before and after anything I replaced.
MAF sensor
